Gary Singleton
I posted several weeks ago needing a little help with 8n lift I have took top cover off transmission and pump. drained all fluid out, and washed out. fluid was yellow. several said I need another control rod from the lift quadrant to inside the bottom of pump housing. am looking for one now and mine looks like it may be bent a little, as I said before I took a wood handle with side cover off and pried it forward about a inch or so and it lifted up. (without equipment on tractor) my question now what do I look for next if that isn't the problem? thanks again Gary
