I just recently bought a 1950 Ford 8N. It was not running at time of purchase, although previous owner swore it would run. (I tried many attempts on existing plugs, wires, etc, to no avail.)
Anyway. I got it running after replacing spark plugs, setting the timing (initial not running timing 4 degrees btdc), new carb, new ignition switch.
However the oil pressure gauge shows 0, not moving, as well as the ammeter for the alternator is not moving. This 8N was converted to 12 volts before I got it.
After the engine ran for about 1 minute I shut it down due to concerns of no oil moving in engine. Also checked dipstick and oil looked undisturbed and still on the full mark.
Is there a simple way to tell if the oil pump is working or not without the gauge working?
I tried to search this forum for similar problem, but no idea HOW to search this forum. Help?
