Got around try and polarize generator are the regulators different early 8hs? Was going to polarize on battery and armature as shown but my vr
is diff. Not next to each other. Mine has wire on outermost bolt holding vr on and at least one wire on the inner side I will have to take breather
off to see if there is another wire. I have three wires on generator ground and field on gen. Barrel marked ground and field and third wire off
back of gen..is the set up for an internally grounded gen.? If so do polarize as described by ploughman for internal ground? If it is it shows
running wire from batt. Side of solenoid to the field on the gen.barrel. Also shows do one ting wire from field post on gen.to voltage reg. Before
touching wire from battery to generator field post . Have I got this right?
