1949 8n, side distributor, converted to 12V.
My new-to-me 8n has been converted to 12V and won't start charging on its own. If I take a screw driver and short between the #1 and #2 terminals, the alternator will start charging.
Read through the forums, consulted the wiring diagrams, and thought I had a solution.
I ran a wire from the switched side of the ignition switch to a small warning light and then to the alternator #1 terminal. When the switch is turned ON, the warning light illuminates, as I believe it should. However, when I start the tractor, the warning light does not extinguish. If I (again) short between the #1 and #2 terminal, the warning light extinguishes.
Can't figure out what I'm forgetting or omitting. Any help would be appreciated.
Photos:
#1 Terminal Block. The blue wires are for the ignition switch. The brown wire runs to the warning light and then on to #1 terminal.
#2 Warning Light in series coming from terminal block and going to terminal #1
#3 Connections at alternator. Jumper from Bat + to #2. Brown wire from warning light.
#4 Warning Light package
Photos:
