Shorter hydraulic pump shaft?
kev518n
My front pump hydraulic shaft i bought 194354 which is 13 inches long is to long. Anyone know of a shorter one that will work or will i have to have this one cut down?
I don't know if there is a shorter one available, but had the same problem.
Couldn't send it back, so I cut the keyed end off to the length I
needed, then cut a new key way in it with a small cutoff wheel.
That was six years ago. So far, so good.
(quoted from post at 19:09:07 01/16/17) I don't know if there is a shorter one available, but had the same problem.
That was kinda my thought that i might have to do it that way.
(quoted from post at 22:11:20 01/16/17)
Not saying it's the best way, but it worked for me.
Steady hand, small adjustments and lots of test fitting.
(quoted from post at 19:17:59 01/16/17)
mine has a woodruff key but i dont see any reason that a straight key wouldnt work.
(quoted from post at 23:22:01 01/16/17)
The round cutoff wheel made a semi-circle for the woodruff key.
I used the one that came with the shaft.
(quoted from post at 23:25:42 01/16/17)
[b:87fc1abba5]"Steady hand"[/b:87fc1abba5]
i need to order one of them.
LOL Mine aren't that way so much anymore either.
I cut mine and put a straight key cut in but I have access to a Bridgeport so it was pretty easy.
I cut them down and re-key them on a regular basis.
TOH
