Changing the crank pulley with pics.
kev518n
I am installing a front mount hydraulic pump to run my loader and to get live hydraulics. So I had to pull the tractor apart and install a new crank pulley. While I was at it I installed a new pivot pin and bushing in the front axle. Mine was worn out. Got the pulley in and the front axle back on and in the process of building the bracket to hold the pump. I will try and finish it up tommorow. Here are some pics
What are you going to use to connect the pump to the shaft? I went with a chain coupler from SurplusCenter.
