G6 at Snook, TX
How much leakage from a radiator it too much? What I mean, is that I have a pin hole leak in a fin or two, and just enough to drip occasionally, but the actual level in the radiator is not noticeably lower.
This is a repop radiator I bought from this site six or seven years ago. It was the restoration grade and has served well in hot conditions. The leak showed up in reaction to the low temps we had around here ten days ago. (17*) Which for south central Texas is low. FYI, I replaced the petcock valve because it looked like the leak, but no good.
Should I fix, or buy new? What is your advice?
