Replaced valve stem cores
Ed S.
Location
Middle Tennessee
After nearly nine years, the valve stem cores on my CaCl loaded tires stopped doing their job. Messy to fix, since all the air had already leaked out, so I got a shower when I made that last twist.
Surprisingly, it was the rubber seal that was gone in the core, not the stem itself.
es
Ed........so the tractor lifed it wheel and peeeeeed on you like a dog???.......(giggle) the amazed Dell
My experience has been, if tire is leaking down sometimes the tube can also be leaking inside the tire,
The valve stem is probably just the start of your problems
Problem this chemical will be rusting and eating away at your wheel,
I would get rid of that material out of the tire as soon as possible,
The weight material they use today works fine and is not corrosive to the wheels,
