9N, 12V Negative Ground conversion, electronic ignition conversion, new carb, new gas tank, new sediment bowl, new battery, new ammeter.
Will not fire. I have good fuel delivery, compression is 110,105,115,120 or so. I checked spark with light tester and with plug at 1/4" gap. All cylinders have light but seems weak. Using the plug I could hear the spark with all cylinders but not see it well, but I could see it here and there. It seemed to jump to the threads before it would jump to the end of the electrode on one or two. My ammeter does not move when starting and the old one did not move when the tractor did run, hence the new one. My starter switch is not stock, its mounted on the side, it was that way when I bought it. There have been times when the starter button sticks and I have to tap it to get it to stop engaging.
The last modification I did was the electronic ignition and the ammeter would not move so I replaced it, have yet to know if it works. The tractor did start one time after the mod and I used it for about an hour, turned it off and hasn't started since. very disappointing.
Thanks in advance
Thanks in advance
