Removed the hydraulic pump
49 8n
Removed the pump and soaked for 24 hrs in diesel fuel . Removed the safety valve and 2 plungers on the rocker arm.
I blew it out with the air hose and have ordered a new valve.
Is there anything else I should be looking at before I re install it?
Thanks . Brian
Blow it out w/ compressed air. Run cleaning fluid into the hydraulic discharge near the test port & make sure you get a good flow out the small hole in the side of the pump were the control valve fits. I don't see much need to pull it down any further just to clean it. But, I always replace the safety valve (p/n 638, about $25)
75 Tips
