Getting an NAA that is new to me ready for bush hogging hopefully this coming summer. I am working on the rear axle. The tractor is on a jack stand on the left side and the right wheel is on the ground. After the left wheel was removed, I noticed that was a little play between the axle and the hub. I could wiggle the hub with my hands about .050 inches from side to side. The hub could be mover radially with my hands about .0100 inches in both forward and reverse directions. Upon getting the hub off, the was a worn area towards the outside end of the axle about .050 inches deep. The teeth in the hub also appeared worn. The thick washer behind the axle nut had a wear pattern on it about .025 inches made by the hub rubbing on it. The axle nut was tight but just pinched the large washer against the shoulder on the axle and was not tight against the hub. The splines of the hub were behind the shoulder of the axle. Plan to replace both the hub and axle. Is this reasonable ?
The right side is a little different. The splines on the hub stick out past the shoulder on the axle. The large washer bears against the hub where the axle nut is tightened. There is no wear marks on the large washer from the hub. However when I was loosening the axle nut I could feel some plat radially between the hub and axle if I turner the axle nut both forward and backwards. Looking at the axle end with the nut remover, there is a little space between the splines on the hub and the axle. I think I can move the hub radially until the hub splines hit the splines on the axle. After the left side is rebuilt, I plan to take the wheel off and do additional looking. I would appreciate any suggestions on what should be done with the right assembly. Do I need to replace anything ? What additional analysis do I need to do ?
I sincerely appreciate any suggestions and thank you for your help.
