Hydraulic pump removal
49 8n . I have all the fluid drained and I am ready to remove the pump as per Bruce's instructions . I have one question first . The loader hydraulics are fed from the tractor pump ,so do I disconnect the line before I unbolt it or is there some sort of disconnect on the inside ?
Thanks . Brian
(quoted from post at 13:32:08 01/02/17) 49 8n . I have all the fluid drained and I am ready to remove the pump as per Bruce's instructions . I have one question first . The loader hydraulics are fed from the tractor pump ,so do I disconnect the line before I unbolt it or is there some sort of disconnect on the inside ?
Thanks . Brian
Disconnect first, it's easier. No connections on the inside. Should just be a banjo bolt into the test port.
