BrianLivingstone
Thanks to all for all of your input . I removed the side covers and found the sump very clean. When I removed the 3 drain plugs the was a lot of
water came out before a milky fluid . I flushed the well 5 times with diesel fluid as suggested and then refilled the sump with fluid.
I tried to bleed the lines the best I could and the loader did eventually lift a few feet off the ground. I tried it again tonight and it was very slow to
lift but if I stood in the bucket it would not hold my weight.
Looks like I need to remove the pump and clean it properly.
Brian
Brian
