Rick B 8N WA
Hoppy gnu ear, y'all.
New problem with my 52 8N, I need advice.
The hydraulic pump hub on the front pulley has stripped out. It appears that the rubber inserts slip over pins on an adapter on the pulley. I believe I have found the replacement part on this site, will order soon. My questions; How much disassembly is required to change this? Hood? Radiator? Front Axle? Does the hub indeed just slip onto pins, or????
Thank you
Thank you
