I "rebuilt" my carb (mostly just replaced bad gaskets and cleaned it up)
When I put it back together and put it on the tractor it poured fuel out of the carb air breather connection. It wouldn't do more then start for 5 seconds about every 10 tries. I'm assuming something isn't seated correctly. I've taken it back apart and I'm currently soaking it in engine decreaser and carb cleaner.
Any recommendations for me when I put it back together?
Also, do I need the little spring looking thing that sits under the float on the valve seat? The video I watched the guy didn't use it and it didn't have one on when I took it apart.
Lastly I can find starting recommendations for the Jets but not the little screw on the back side that won't come out because of the stud. Should this screw be down tight?
