to30man
The piece the switch goes to looks like the
top side is broke off. What do you call that
piece to get another or am I looking at
something wrong
I looked at my local auto parts and farm and garden and had no luck finding this piece were is a good place to get one new
(quoted from post at 13:52:21 12/16/16) I looked at my local auto parts and farm and garden and had no luck finding this piece were is a good place to get one new
If you want one just like the original, this sites sells them, shipping might get a bit high for one small item tho. or if you want something that will work but look different check ebay,
Looks like what you got will work. All it is, is a place to hook wires together.
It shows that some wires go on top and some go on the bottom and the top is gone on the one I got can you put them All on the bottom ?
there's a reason there are 2-posts (screws?) separate circuits. So the answer to yer question, is NO. You kenn NOT consolidate all yer wires to the 1-post. ..........HTH, the amazed Dell
You could use any separate, two post connection block.
Hooking them all together will not work though.
The key switch needs to connect across the two sides to turn
it on and off. I have used Radio Shack connectors in the past.
They are a pain as they are really too small for the wires.
Plus, you have to find a way to mount them.
If you can soak your old one in penetrating oil front and back,
then get the screws to turn out, the original style would be my
first choice.
There are other options too, like converting it to key start.
However just to get it running I would start cheap.
Hot wire the distributor and worry about all the rest later.
If it runs well, then replace all the wiring as you wish.
