(quoted from post at 11:00:03 12/15/16) I have acquired a disc plow that I am told fits between the front and rear wheels on an N Series Tractor. I'm not sure if it fits them all or only a select few. There is no nameplate identification anywhere on this plow. Has anyone ever seen or heard of this? I would like to find out some information concerning this that would help mount this on the tractor. If anyone has any information or pictures, that would be a BIG help. I've tried searching this on my own but so far have come up empty. THANKS in advance for your help!!
Hey Mulehead,
As often happens, you've probably tried to post a photo and failed.
[b:40fcc735b3]Two things:[/b:40fcc735b3]
FIRSTLY:
You need to have a few posts (5 or 6 I think) before you can upload a photo.
SECONDLY
Photo Attaching
Forget that big "Choose File" button lower down that you've probably tried.
That method hasn't worked since this YT Forum developed problems a while back, where the normal photo uploading method ceased to function as did the option to go back and EDIT (change) what you had posted.
Below where I am typing this to you right now,
You'll see: ADVANCED POSTING TOOLS in a [color=red:40fcc735b3]red banner heading.[/color:40fcc735b3]
In the blue colored options there, click:
[b:40fcc735b3]Upload Photo[/b:40fcc735b3]
THEN in new pane that opens --> [b:40fcc735b3]Choose File[/b:40fcc735b3]
THEN ---> [b:40fcc735b3]Upload [/b:40fcc735b3]
THEN if you are satisfied that the visual preview is your chosen photo,
click the [b:40fcc735b3]CONTINUE[/b:40fcc735b3] button just above the little preview of your photo.
the photo link will appear in the text body of your post.
Finally, click the usual big [b:40fcc735b3]SUBMIT[/b:40fcc735b3] button that you normally use to post a message.
Don't worry about filling in all the other fields in that pane; i.e., Make, Model, Year etc. It isn't necessary to add that info.
