8N Ground Strap
Jim WI
I'm replacing a dead battery on a sidemount 8N and discovered that the clamps on the battery cables are worn out. I'm looking to order a ground strap but there are two available. One is 5.5 inches long and the other is 11 inches long. I guess the best length to order would be determined by where it goes to.
What is the correct point to bolt the strap to?
Wow! Something that was done almost correctly on this tractor! Now if they had just used a braided ground strap (or even a nice heavy cable).
