Davis-Midwestern loader on 48 8N
52geemsee
In the process of refurbishing a Davis-Midwestern FEL that was on my 8N when I acquired it. I have everything except the cylinder for the bucket. This is an 101 model, (I think), and it uses a single cylinder in the center of the loader to operate the bucket. It is a double action cylinder.
If anyone could tell me the cylinder size and length of stroke, it would be appreciated.
Here is the part number but I can't find the dimensions.If you find the length you might try and match up here
Massey Ferguson671 005 M91 hydraulic cylinder
Davis 756-A-O cylinder
cylinders
I think I found it.
Bore 2 1/2"
Stroke 15 3/16"
Rod diameter 1 1/4"
If anyone can verify if those dimensions are correct, please post..
Thanks
(quoted from post at 00:31:57 12/01/16) In the process of refurbishing a Davis-Midwestern FEL that was on my 8N when I acquired it. I have everything except the cylinder for the bucket. This is an 101 model, (I think), and it uses a single cylinder in the center of the loader to operate the bucket. It is a double action cylinder.
Davis Model 101 Bucket cylinder:
Bore - 2-1/2"
Stroke: 15-3/16"
Rod - 1-1/4"
You should be able to find something here although you will probably have to get creative with the attaching points:
[u:50bbc95484]Surplus Center DA cylinders[/u:50bbc95484]
TOH
(quoted from post at 08:26:25 12/01/16)
I think I found it.
Bore 2 1/2"
Stroke 15 3/16"
Rod diameter 1 1/4"
Thanks
That's what the 101 manual says. You should verify the stroke and closed length dimensions as well as the dimensions of the attaching points at the ends by measuring the loader before buying new cylinders.
