8N whines and won't start
fredharts
Yesterday I'm on my 8N and I stop it. I go back to start it again and it whines but starts. Then I finished what I was doing and decided to stop it to see if it whined again. So I push down on the button to start it and it just let out a big whine and wouldn't start.
The whine is coming from the solenoid or starter I can't tell. It just whines and whines when I push down the button and never starts.
Any ideas?
" Any ideas? "
Yes.
Your bendix isn't engaging.
6 volt or 12 volt?
That is likely caused by:
1. A weak battery (charge it & check it per tip # 49. Or get it load tested.)
2. Dirty grounds/connections (remove the cables & clean the connections)
3. Bad cables or incorrect sized cables (replace them - see tip # 41)
4. Bad ground between the starter & the block. (pull the starter away from the block & clean the mating area - see tip # 36)
5. A dirty/greasy starter shaft.
6. A bad bendix.
75 Tips
(quoted from post at 07:51:28 11/26/16) " Any ideas? "
Yes.
6 volt or 12 volt?
6. A bad bendix.
75 Tips
12
1. Battery is good
2. I cleaned the positive but not the negative will try negative when I get out there.
3. Cables are good.
4. Do you have a picture so I know? I'm sure it's dirty
5. This is very likely. Which shaft are you talking about.
6. I think this is the least likely.
" 1. Battery is good"
How do you know that? Load test? Hydrometer? Voltage drop test?
" 2. I cleaned the positive but not the negative will try negative when I get out there"
That would be a good idea. Cleaning one & not the other is a waste of time. It's a circuit.
" 5. This is very likely. Which shaft are you talking about."
" 6. I think this is the least likely."
As you have a 12 volt tractor, I'd say this is a very likely possibility.
The starter shaft.
75 Tips
Sounds like the starter drive is not engaging.
Load test the battery and verify properly sized cables first.
Dean
