lanezupkov
New User
I had my engine rebuilt recently and the tractor starts and runs beautifully EXCEPT this very random metallic knock or ping. I say random because it is not cyclical. It starts this sound after a few minutes of running.
I was so convinced it was a nut banging around in the oil pan that I dropped the pan but there was nothing in there, everything looked tight and I didn't see any signs of metal on metal scaring except the oil pickup tube was scratching on the oil pan. I also removed the guts for the governor since I thought it could be a ball hitting the case. no luck. When I do the long screwdriver to the ear trick the noise sounds the loudest in the oil pan, timing cover, exhaust manifold, and clutch housing (all sound chambers?).
I'm leaning towards pre-ignition knock but I've never heard engine knock in person also it i most noticeable at idle. I'm tempted to put in ear plugs and start mowing.
