8N Fly wheel marks
Larry7
New User
I think my flywheel has been changed at one point because all it has on it is a straight LINE then rotate and comes to the letter B ! How do I set distributor to these markings !
Larryr
8N, side distributor? I can't remember the number of teeth.....JMOR does and maybe he can help......but if he isn't around, count the teeth, divided by 360. That gives you the number of degrees per tooth. Find TDC on #1, mark the flywheel, then use the specs to make the appropriate marks on it.
75 Tips
