I ahve a '49 8N I have been bringing back from the dead. The prior owner did it no favors. I changed fluids, points, cap, rotor, plug wires, spark plugs, rebuilt the carb, new fuel line, new sediment bowl, cleaned the tank, among other things. First issue was that the distributor grounded out, and It wouldn't start. Fixed that and it started, but only wanted to run with the choke out a little. If I held the choke in the sweet spot, I could throttle up fine and it ran fine.
I drained the tank, took apart the carb, and checked filters after checking fuel flow. Flow seemed okay at first but then a little more of a trickle. Put everything back together again and it started right up and idled fine without the choke pulled, but when I try to throttle it up, it runs rough and will die. It now only likes idle and slightly above.
Nothing else has been changed between the two rounds.
I will check spark tomorrow, but what else? Why such a difference in the way it runs when nothing else changed?
Thanks
Thanks
