51 8n Clutch pedal
I just bought an 8N to restore and the clutch pedal looks like it was broken at some point and rewelded but Farmer John only welded 1/2 of the pedal arm the side away from the tractor. It was broken about 6 inches below the pedal. I need to remove the pedal and weld it properly but I don't see a pinch bolt or any way to remove it. How can I remove the arm to weld it? Thanks
Skip,You have to take the left brake pedal off the cross shaft on the right side bolt 6 and the left brake arm 17 loose on the left side.Then slide the shaft out of the clutch pedal.
Where are you located Skip? I might have a good used one
if you're close enough that shipping wouldn't kill the deal.
I'll have to look to make sure.
I'll take a look tomorrow Skip. If it doesn't snow. ;)
I'm in central Michigan. Shipping shouldn't be too bad.
Guess what Skip? It's snowing!
Actually a mix of snow and rain but a cold, windy, miserable day.
I did check indoors and did not find one.
95% sure I have one outside, still in the transmission casing.
I'll get some pictures tomorrow when the weather is nicer.
You can email me at RoyseTractors at gmail.com if you like.
I can send them via email or post them here. Either way.
Royse you are the man. I will send you an e mail right now. Thanks a million I am heading out to my shop now to pull the shaft ou.t my only dread fear is that I will hear something inside the tractor go "clink" and then I will be elbow deep in the transmission feeling around for something
