hotdawg1984
OK, I know that somebody out there knows the answer to this cause I know I am not the only one who has ever replaced the sleeves in an 8N.
This engine had the .090 sleeves and the were worn beyond 20 thousands, so I pulled them.
Built a sleeve puller from some scrap I had laying around and pulled the sleeves from my 8N. Sleeves were real tight and took a while to get them all out. After each one I saw that the cylinder was wet with oil, maybe, and smelled like burnt oil.
I wonder if whoever installed them the last time coated them with oil before installing them??
My question is,
1) should I use and oil on the liners before installing?
AND
2) is it necessary to use Loctite on the sleeves, even if they are a real tight fit?
Thanks to all for any advice.
My question is,
AND
