48 8n hysraulic compartment tick
boler76
noticed a ticking noise like a gear tooth but it is coming from hydraulic compartment and with rear wheel off ground and in neutral , turning the wheel by hand the noise is numerous times per revolution, , but no noise when turning wheel backwards, is there something in that compartment that should make that noise , tried with PTO lever in both positions same results? Thanks
and another thing that might offer a clue: diff ratio is 6.6 to one, so with one wheel locked and the other turning , are the ticks around 6 or 13 to one?
