8n pto shaft reinstallation problem
Mrhankey65
New User
I just installed a hydraulic pump rebuild kit on my 8n. All went back together well except when I tried to reinstall the pto shaft. If the brass pto shaft bushing is in place in the back of the pump, the shaft will not reinsert properly. If I leave the bushing out, the shaft will reinsert properly. I finally got the shaft reinserted with bushing only partially in the pump but it causes to much tension on the shaft. Has anybody dealt with this or have any suggestions.
Thanks in advance
If a brass bushing is a little too tight you should be able to
ream or hone it to fit. I haven't had to do one on the PTO
shaft but I've had to do them on the front end spindles.
I would want to make sure it was actually too tight and not
a case of misalignment first. Does it fit the shaft when out?
