Jim in Western MI
My "new to me" 1958 631 started fine and ran great since February when it came with a small farm. It is a powerful tractor in the mountains compared to either of the 8N's I have. It had not been run for at least a couple years. I purged the fuel tank, cleaned and checked the points, installed new battery and replaced corroded cables prior to trying to start it the first time. Since then, it started on the 3rd or 4th rev with a quick touch of choke. But this Saturday it started with difficulty and with great amounts of black smoke, ran very rough and cut off within seconds. Restarted the same way, lots of black smoke. Finally got it to run a couple minutes, stumbling much, and checked the idle mixture screw with no effect through several turns, beginning with one full turn from seated. Do you carb experts see what I could have missed? I think it must be a stuck or sunken float..., could be original from 1958, no way to know. Did some rapping on the carb bowl with no affect. Can the 631 carbs be rebuilt as easy as the N's? (I always wanted one of GB's or Royse's beautiful works-of-art anyway!)
