ford NAA.what is this bracket for?
Picture didn't show up Rick, maybe just because you just joined.
If you want to email it to me I'll post it for you.
RoyseTractors "at" gmail.com
here is the pics.
You got it! Tail light/work light bracket for the rear.
It bolts on with the fender skins to the fender supports.
On the left in my picture here, holding the light.
Yours is a left bracket. They are nearly the same for the
right side but the curve in the end of the channel is reversed.
(quoted from post at 00:15:41 10/16/16) thank you Royse. i will have more pics and what is this posts as i continue to assemble the old ford.
You're welcome, glad to help.
Tim's picture actually shows the tractor and lights set up closer
to how they should be. Work light on the right side, red/tail
light on the left so it is toward the center line of the road where
the red lights were intended to be used. His also looks to be a
Taurus brand light which would be correct for his 8N.
I've got a Taurus light out here on the shelf. Hoping to put it
on my 8N once I get around to refurbishing that tractor.
Long list of projects! :)
Where did you find that awesome umbrella?
(quoted from post at 01:42:01 10/17/16) Yep, fender light bracket for the left fender -right side symmetrically opposite. I have original lights if interested...
<center><img src="http://i15.photobucket.com/albums/a379/ploughNman/8NI55I38.jpg"></center>
Tim *PloughNman* Daley(MI)
Those are some pretty sassy rear tires there Tim. I don't believe I've ever seen that style before.Who makes 'em? Mike
