ehrigranch
New User
Thanks in advance for any help. I have seen numerous posts concerning this issue but no posts with solution.
Issue: 1952 Ford 8N will backfire and not start. Fuel flow is fine, Replaced following with New 1. Spark plug wires & Coil / Cap wire, 2. 12 volt Coil , 3.Rotor, 4. Cap, 5. Points ( gapped correctly), 6. condenser. No obstructions in exhaust. It has been converted to 12 volt in the past and has ran like a top. All firing sequence is correct with cap #1 toward block, firing counterclockwise rotation to #2, then 4, then 3 with #1 toward radiator. Any one that has had this problem and solved it any help would be greatly appreciated.
