will 8n wiring harness fit a 9n?
SDE
I see that an 8n harness is 14.63 on here. Will it fit a 9n? Is a 8n 12 volt?
Thank you
SDE
Wiring is different. Different generator, voltage regulator vs cutout, solenoid vs mechanical start switch. Google wiring diagrams by JMOR.
" Will it fit a 9n? Is a 8n 12 volt?"
That's sorta like asking " Did you bring your lunch or did you walk to work?"
All N's came from the factory as 6 volt, positive ground. All N's can be converted to 12 volt with an alternator or a generator.
The wiring harness is determined by the location of the distributor: front or side.
All 2 & 9N's had front distributors. Some 8N's (all 48 & 49 & early 50's) had front distributors.
Tell us what you have & what you want to do & you'll get plenty of help.
Using my amazing powers of clairvoyance, I'll say you have a 12 volt 9N & need a wiring harness.
75 Tips
Thank you. I thought that the wires might be a little longer to reach a side mount distributor. I am not confident to buy one on ebay and get the correct one either. They list NH with the 9n and I would think a more modern tractor would be a much different harness.
TY
SDE
