Ford1
New User
Hi guys I'm new here and I've got a question I've got a 40 9n and I'm
in the middle of an overhaul and me being me I bought a bunch of
parts b4 I knew what I had I bought a master overhaul kit from
yesterday and I got the 4 ring piston and after reading forms I should
have went with 3 ringer. Any way my question is can I just put the
three rings on like a normal 3 ringer and just leave off the forth ring
on the bottom??
(quoted from post at 22:18:37 10/12/16) Hi guys I'm new here and I've got a question I've got a 40 9n and I'm
on the bottom??
Much ado over very little. Use them as designed and don't worry. Four ring pistons were original fitment in the N series and have been used successfully in tens of thousands of engines of all makes and models.
TOH
Ford1.........make a "spool" outta 2-pieces of semi-round wood to fit INSIDE yer sleeve and a 12" length of 1/2" all thread and 4 matching nuts. Then gitt some DRY-ICE chips from grocery store or other seller (look in yellow pages) The -130* dry ice will shrink yer sleeves and now just install yer sleeve inna yer block. Unbolt yer bottom wood piece and catch the chips of dry-ice inna bucket and repeat fer yer next sleeve. When the dry-ice falls outta yer sleeve, the sleeve will naturally expand to fit yer block cylinder hole. NO HAMMERING or POUNDING required. Just wear gloves to protect yer hands from dry-ice burns. Simple, eh?.........the amazed Dell
