9n snowplow
tully
New User
does any co. still make snowplows for 9n's
new or used I don't care.
thanks in advance for any help.
I assume you mean front mount snow plows?
Back blades are available for any three point equipped tractor.
I honestly can't tell you if anyone offers new front mount blades.
They are certainly available used though.
The one on my 2N I thought was home made, but I have since
seen several more that are identical to it so I now think it was
factory built. Maybe a small factory or localized shop, but they
were too much alike to be fabricated by different people.
The one on the 8N was home built by a retired GM machinist.
He does great work. It would lift high enough to dent the hood.
He corrected that, but it will still pile snow WAY higher than the
one on my 2N. Not to mention lifting high enough not to get stuck.
Dearborn or ARPS snowplow were made for the N tractor. If you are local I have a Dearborn snowplow I will be putting up sale in a couple of weeks. My email is open.
You might also want to consider building a frame and buying an old truck snowplow blade. They aren't that hard to build.
Kirk
Here's one frame I made out of angle iron for a few years back. Just add an old truck plow and your in business.
Kirk
I have a Souder plow....with hyd lift that operates very well with original system with no modifications .....just a fitting or two.....would part with.....Excellent condition....let me know if interested and will snap some photos...
Open [email protected]
Cheers!
(quoted from post at 09:12:54 10/13/16) I have a Souder plow....with hyd lift that operates very well with original system with no modifications .....just a fitting or two.....would part with.....Excellent condition....let me know if interested and will snap some photos...
Cheers!
Lots of good pictures here. It's actually the dozer version but it gives you the basic idea....
Sauder Dozer/Snow Plow
TOH
