Replacement carb
J20in1st
New User
Is there any difference between the cast iron and the metal replacement carbs?
Other then look I just need a functional carb
48 8n
I would buy an original carb on ebay and rebuild it. Those old MS carbs are hard to beat.
I can get one for $30 @ a local yard but by the time I drive there and rebuild it if inured I might as well buy a new one and know I don't have any issues.
"I might as well buy a new one and know I don't have any issues."
No guarantees there. New ones come off an assembly line.
They aren't tested or adjusted, just assembled.
If you really want a new one the cheaper ones that YT sells,
[b:a749aeeff9]this one[/b:a749aeeff9] seem to work Ok. I avoid the no-name black ones.
The brass main adjustment screw itself comes in the rebuild kit.
If the hole is stripped out that would be a bit tougher.
Yes the hole is stripped, cross threaded not
stripped yet technically. Local shop quoted
me 200 to fix and rebuild. F that
If you're getting rid of the original one I'd be interested in it.
Email is RoyseTractors at gmail.com
