8N Ford transmission
John-MI
Can you change the mainshaft front bearing without taking out the mainshaft. The IT manual is not very clear on this. It is a 4speed transmission in an 8N Ford. Thanks. John
If you are clever enoufh its possible Its probably not the tight. I would replace all the bearings if ones bad more than likely the rest are also.
