There are two versions, early is 9/16" gear length Later is 3/4" gear length.
Are there other differences, gear or shaft diameter? Cause, if not I may try making a spacer of something suitable, Aluminum or Steel. To push a little more oil.
I have modest machining facilities. Definitely enough to make a spacer an maybe some mods to pump body/end cap.
