2000 Ford Front end Loader Want down presure
bobinmi.
Have a later 3 cyl. gas 2000 with a trip bucket loader and we want to change it over to 2 way cylinder and need to know how to plumb to the tractor. At this time it is up only with gravity down, single control under seat.
Is there another way to plumb this tractor for 2 way cylinders, will use joy stick type controller. Also has 3 point hitch.
Can post pictures if needed.
Thanks, Bob
(quoted from post at 14:43:20 09/30/16) Have a later 3 cyl. gas 2000 with a trip bucket loader and we want to change it over to 2 way cylinder and need to know how to plumb to the tractor. At this time it is up only with gravity down, single control under seat.
Thanks, Bob
Ditch the underseat valve and install one of these remote port adapters in it's place. It will give you OUT, RTN, and PB ports that you can use to plumb your joy stick valve.
TOH
Remote adapter kit
the tisco part number is hv5902.
i couldn't figure out how i had screwed up the link until i tried it again. the forum software here is actively censoring it, which explains why hokie's link was non-functional to begin with :x
(quoted from post at 17:15:39 10/02/16) Sorry not 2000 but a 3000. Do you know the
Tisco #, both the links posted I could not
get to work.
This site keeps bunging that Tisco link, Here is a "sanitized" link in plain text. Remove the dash in tisco-parts to get it to work.
https://tisco-parts.com/partcategories/hydraulics/valves/hv5902.html
It gives you an Out, Power Beyond, and Return port which is what you want for your loader valve:
OUT on HV5902 to IN on valve
POWER BEYOND on valve to POWER BEYOND on HV5902
RETURN/TANK on valve to RETURN on HV5902
There is another less expensive and more readily available version - HV4902 - that only gives you an Out and Return. You can make it work with a power beyond valve by connecting it as follows:
OUT from HV4902 to IN on valve
POWER BEYOND on valve to RETURN on HV4902
RETURN/TANK on valve to oil filler cap on tractor.
TOH
