I bought all of the parts to rebuild my hydraulic pump from YT. The valve chambers are very well machined, but they are universal fit, that is, they will fit either side depending on where removable plugs are installed. The issue is that they are too thick and won't go up into the tractor. I called YT, and that are the only ones they sell. After some side grinder and file work, I got it to clear the bolt hole bosses in the bottom of the tractor. I thought I was in good shape until I discovered that it won't clear the hydraulic stand pipe on the right side, and there is no way to make it fit. The castings of the replacement bodies seem to have random thickness. I was wondering if anyone else had run into this problem. Thanks,
Roland
Roland
