After setting in a pasture for fifty years, I was able to bring my 8n back to life using many tips from this website. The tractor had a Davis FEL on
it but I removed it to make working on the tractor easier.
I now am ready to rebuild the FEL and I need to flush out the oil reservoir which is in the frame work of the loader. The drain plug for the
reservoir does not appear to be on the very bottom of the reservoir and I worry about not getting all the junk cleaned out of the reservoir
completely. While in the process of getting the tractor running, the front mount pump did pump oil which leaked out from the loader control
valve. The oil was creamy white which to indicates it has water in it. Any suggestions on how to clean out the reservoir would be appreciated.
Also wondering what it would take to rebuild the loader lift cylinders.
Thanks for your help
