8N rod bearing orientation
igobill
New User
So I'm rebuilding an old 9N tractor engine and I come to the part where the rod bearings are installed. Thats where I noticed that the notches on the cap bearing and the connecting rod bearing don't match when installed. The notches can either be on the same side (but offset) or the cap notch can be on the opposite side. Unfortunately I did not check the orientation during disassembly. Which way are the connecting rod bearing notch and the cap bearing notch oriented?
Thanks for your help.
(quoted from post at 17:05:43 09/30/16) Thanks a lot JMOR. This forum has been a life line to information from those who know and have done.
ou are welcome!
mine were punch marked showing cylinder location of each rod as stated in FO-4, the punch marks on cap and rod faced each other.
