BlackThumbHomesteader
12v with the front mount distributor converted to use a 12v round can coil.
Points have less than 5 hours
Condenser changed at the same time as the points.
Proper point-gap was set and timing is spot on.
Battery showing 12.8v at the terminals.
Toggle switch(not a key switch) tested good with the meter.
Cleaned the battery ground at both ends, battery positive at both ends, starter connection at both ends.
Getting 6.8v at the starter with the toggle switch on.
Was out working and had to stop to pull some clutter out of my path so I turned off the tractor to do the work. Came back 10 minutes later and the starter won't turn at all. No click, buzz, whirr, or thunk at all when the starter button is pressed. What else should I look at to figure this out?
