Kenockee 8N
Hi all. I'm in the process of replacing hubs and axle shafts and I have one side apart. The other side I cannot get the counter-sunk screws that hold the drum onto the hub off. I've tried PB Blaster, heat, an impact and then a chisel hammered on the right side of the flat in a counter-clockwise direction with no luck.
I've seen other posts where people have had the same problem and drilled the head off. Seeing as the screw only holds the drums on when the tires are off, is it safe to drill them out and move on or should I continue to struggle with this? Am I missing something to try to get these off?
Thanks!
Thanks!
