Ring gear replacement
Murray2
Purchased a ring gear for the (early) 8n a few years ago. The ring gear now has to be replaced. Being as the tractor needs to be split, my thoughts is to replace clutch and pressure plate and bearing and what ever else that should be replaced. If anyone has this information along with the Parts numbers this would be appreciated. I do have the Ford manual. Thanks for any and all advice. Cheers, Murray
Transmission input shaft seal. I don't have a number handy. it is only a 5 to 10 minuet job while you are in there.
Check out tip # 59.
Have the flywheel resurfaced and the clutch and p/ p rebuilt. Replace the t/o and pilot bearings along with the transmission seal and gasket. I'd also replace the bendix means you have a new ring gear.
75 Tips
