CalebHummell
Bruce, in Tip 31 you say something about a piece of wire with a j-hook on the end. Not sure what that's about. There's a missing word or character in that line also.
I have an early-model 8N with the square pipe plug. I've removed the plug and am considering replacing it with a zerk and filling the housing with cornhead grease as others have suggested. My question is, with a zerk, where will any over-fill come out? Am I likely to damage anything (blow a gasket/seal, etc.) if I get too much cornhead grease by way of the zerk? Or, am I better off leaving well enough alone and just replacing the pipe plug?
What's in there now, from whoever owned it before me, is really thick stuff. Looks like heavy-duty bearing grease with the consistency of NGLI #2 or Vaseline. Do I need to disassemble and clean out the thick grease before using cornhead grease?
Thanks for the help.
