CalebHummell
Hi, all.
I've read as many threads as I can find regarding engine heaters for winter starts. I've read the suggestions about mag heaters, lower radiator hose heaters, heat lamps, keeping battery warm, the doubtfulness of freeze plug heaters, engine oil weight for winter use, clean/tight/bright, etc.
So, here are a few questions:
1) What's the size of the 8N lower radiator hose for Kat's or ZeroStart lower radiator hose heaters? Somewhere I read 1 3/8" but want to make sure. Sounds like this is the best all-around solution.
2) Do dip stick heaters do any good? If so, are there specific manufacturer recommendations? Every one I've looked at online is specific to a particular car model.
3) Someone on this board talked about 3-point/transmission heater. Is that something different from a magnetic heater? Is there any advantage to tranny heating, aside from longer waits for engine heat to make it back there to warm up the 90 wt?
4) Regarding transmission/clutch pedal in winter: Is it better to chock the wheels and leave the tractor in neutral rather than have to take it out of gear to start?
Thanks.
Thanks.
