Ford 8N starter solenoid
gmueller
New User
Can I use a 12 volt solenoid to replace a 6v. My battery is 12 v. Tractor was converted from 6 to 12. I assumed solenoid was 12 since battery was. When I removed old solenoid discovered it was 6 and I had ordered a 12 v solenoid.
(quoted from post at 13:47:34 09/16/16) Can I use a 12 volt solenoid to replace a 6v. My battery is 12 v. Tractor was converted from 6 to 12. I assumed solenoid was 12 since battery was. When I removed old solenoid discovered it was 6 and I had ordered a 12 v solenoid.
es, if of same "type", where ground to the small terminal activates it. If you get one that requires voltage applied to small terminal to activate, it won't work as a replacement.
(quoted from post at 11:01:59 09/16/16)
Mine was hooked up with a wire from the small terminal to the foot switch. There was a wire also from the battery + connection to the ignition key switch.
(quoted from post at 15:04:24 09/16/16)
ounds OK, although, Battery+ to ign sw will generally pass through ammeter.
Actually it might go thru ammeter and then to keys with.
I don't remember but I did not remove or disconnect any of that. Just the solenoid connections. Thanks.
