mb58
The lift arms on my 841 will not lift my disk or any other heavy three point implement. I thought it would be the oring on the cylinder leaking. But when I hooked a pull type bush hog to the hitch bar between my lift arms, the lift arms raise up on their own and refuse to go down regardless of the position of the lift lever. Any ideas?
First thing I would check. Are you in Position Control mode.
Sitting in the seat, reach down on the right side. The lever should be horizontal.
