Skeeter102
My 8n is leaking from the test port. this leak developed a good while after installing my live hydraulics setup. I noticed a leak and then tightened the fitting down with a wrench but it came back with a vengeance. I guess this is what screwed up the fitting.
I took the sae 5 fitting out to find the hydraulic pump deformed in a perfect circle and the o ring split in two. In there any fix or should I just swap in the hydraulic pump from my basket case 8n?
