PrestonKing
Good Morning All,
I need to check the gap on my ignition points. How do you all turn over the crank to have the point block resting correctly on the distbr shaft? I have a remote push-button starter switch but, forgot how to hook it up. Maybe I don't need to use the remote switch and can just turn the crank with the fan??? All thoughts and suggestions are welcomed. Thanks.
