FarmerBlair
Hi,
I removed the topcover on the rear housing of my 1950 8N and found a round disc laying at the bottom of sump. Its about the size of an old silver dollar and about as thick (maybe inch and half in diameter). It has smooth surfaces and no holes in it. It was laying in the rear right corner of the housing. Anyone have an idea what it is for? The hydraulics have been weak and I found oil gushing from the topcover when I looked in the side port. Planning to just replace the piston rings and gasket to see if that fixes the problem.
Thank you
Thank you
